I just got to thinking...would it be easier or cheaper to replace the bad pinion bearing(s) in my 10-bolt rather than replacing the whole axle with a used one?
I'm starting to get a little anxious about getting the K5 back on the road and selling off my current DD. I got laid off and I'll drop off payroll at the end of September. I want this done ASAP.
I'm still going to get the 1-ton running gear, but it'll be incomplete to start with--it'll take time and money to prep them for the swap, plus any other parts I may need to do the swap.
If I try to just replace the pinion bearings and seal, will I need to complete setup up the rear again with new shims to get the proper pinion depth or what?
Thanks,
Thanks,
