I did block tires, and tried clicking it once. I’ll try more tomorrow . I’ll have to go buy another multi-meter, to see if I have voltage anywhere . Really frustrating without one. Even my continuity tester stopped working… THXthe switch at steering column, you can jumper the plug there to check the circuit. probably the switch and/or the adjustment
Your fronts have bad or no groundStill don't have tester, hopefully go to town tomorrow and get one. Ran into another baffler today, I have rear running lights, but no fronts, not even with headlights on ?
They blink with signals on, but that's it. Replaced both bulbs too.
This thing’s been a wiring and lack of or no ground or loose ground Nightmare since I bought it couple years ago.Your fronts have bad or no ground
I forgot to say I had left bulb come on and had to replace that socket because it was wired in with 1157 socket. Actually more like hacked in , so I got an 1156 socket out of a friends parts truck . I do think your correct, I remember seeing a trailer wire splice somewhere back there. I'll check that out today, Thank You.
