COChris
Registered Member
Ok, so I signed up for this and its time to use it. I finally made it to Blazer bash this year and had the time of my life! but needles to say it means that i now know what needs to be fixed.
Lets start with the basics, here is what I have:
79 blazer
454 with jet stage 2 Q-jet
SM465 np205
Dana 44 front/open with 4.56 gears and full Hydo steering 4" leaf springs
14 bolt rear with 4.56, Detroit locker, drums, stock springs with an at home approach to the shackle flip
39.5x13R15 Irok's
She performed well this year but i have this need to do better next year. I will say that Breaking my front drive shaft on the Trifecta run was probably one of the best things that could have happened to me, it forced me to make a driving change. Less skinny peddle and figure out the bump. The things that will change no matter what are the rear tire carrier and mounting the winch up front instead of in the receiver hitch. I bashed open the cover on my winch and I dont even know if it still works. I also do not like having so much weight hanging so far back, and the decreased departure angle.
Here are my thoughts and questions.
Front suspension: I wouldn't mind moving the front axle forward a little (no problem with steering, the hoses are long enough) and I am debating between running 56" springs with the stock mounts flipping sides and or doing a 52" setup like the B52 from diy. I plan on doing the front end first, the back end is in better shape and i want to do it before I have my new front drive shaft made. I want to stick to around 4" of lift, fenders are trimmed and more can be hacked, nicely, if needed.
Front End: I would like to find a Dana 60 and remove my weaker 44 but that may not be in the budget. I have come this far with an open 44 I can go a little bit further if needed. I have also been debating putting good shafts in the 44 and a selectable locker, but I am thinking that would be money wasted in the long run.
Rear Suspension: My home made shackle flip has seen better days and it is time to replace it. I have been going back and forth between the DIY kit and the ORD Kit. I like the stock spring but wouldn't mind more flex. I do not want to move the rear axle back much, as I am keeping the gas tank in the stock location, I have a heck of a beefy skid plate on it that is integrated with my rear bumper. I am looking for pros and cons of each kit and I want to stick around 4"of lift. I am not afraid to trim sheet metal.
Rear end: All i want to do to the rear end is disc breaks/parking break. I am not to worried about that it will just have to include Cadillac calipers and many companies make brackets. My only hickup will be to determine how to be st do the proportioning. either a valve or a new master cylinder.
Fuel Injection: I want to do it, but it has to be on the cheap. I have a multi port fuel injection setup off of a 98 3500 vortec and have been trying to graft it on but i keep getting held up by a crank trigger problem. I have an old school block with no trigger and the trigger is in the timeing chain cover, which they changed. the manifold should bolt up with the correct gaskets. Also when i run the math it may be cheaper to buy a throttle body kit and install it then to buy all of the parts and pieces to scab this one together. I know the computer works, i have wired it on my bench and had a buddy bring all of his fancy scan tools over and just a couple of sensors are bad but the computer communicates just fine. any suggestion?
Some of you may have seen me there, or even seen my wheels off the ground and then shattering my Front drive shaft. All good advice will be taken into consideration. Please note this build will take me a while because I work out of country in Haiti. Like I said above the front suspension is where i want to start.
Chris
79 blazer
SM465 np205
39.5x13R15 Irok's
Chris
seriously all the ones I have rigged up have just been using old bicycle parts, the brakes, shifters etc.
or that you shouldn't get one, it's what my vehicles have. You said it may not be in the budget. I simply meant you don't need to do that 1st as you've proven. Not being confident in your "homemade" rear flip would seem like more of an affordable priority. My hype comment was more towards the 1st response to your questions. I agree putting money in your 44 would be a waste and you've gotten some great advice here.
