c130fly
Registered Member
I'm very new to this posting so if do something wrong lemme know,
K, here it is, I have acquired a 1985 k-5 silverado with a tbi system of a 90 or 91 k20 suburban. It has a 1987-1995 tbi crate motor fairly new,
1990 700r4
Edlebrock tbi performance intake 3704
Stock tbi throttle body, did have a Holley setup when I got it,
Chevy 12 bolt rear
208c transfer case
4" lift 35" tires
MSD 8.5 wires
AC CR 43ts plugs gapped to 35
Inline napa p70428 fuel pump
EVRV egr system disconnected and plugged
A-1 cardonde distributer
Fuel pressure constant 13.5 psi
Has 1227747 computer with ASDU prom
When I got the blazer spark knock sensor was removed and it was timed approx 30 after tdc, ??? Black smoke at idle with the smell of fuel
I added the sensor and reset the timing to 0deg with wire disconnected,
Still rich and spark knock while revving and worse under load, replaced plugs throttle body, intake gasket, vacuum lines, ESC, ICM, fuel pressure regulator, added fuel pressure gauge, ECT sensor 3 times, map sensor, IAC valve, (I have 4 of them) computer (have 5 of those), also when I got it the instrument cluster was still the 1985 and no optical sensor was there, replaced instruments luster with a 1988 installed the dash optical sensor it was still wired for it, ran the check engine light for codes and nothing but code 12, usual.
The only difference I can see with the wiring harness is it was setup for the th400 which came with a downshift relay and no 4th gear input to ECM but the truck still has the vacuum switch and 4wd relay for tcc lockup, and for that they looped the egr bleed off yellow wire back to the blue wire. There's no egr bleed off.
So does anyone else have some idea's?
1990 700r4
Chevy 12 bolt rear
208c transfer case
4" lift 35" tires
MSD 8.5 wires
so i won't know for sure if that's the issue till Monday, so what are ur thoughts?
pulled the plugs and all off them were fouled out. Looked at the driver side injector while running, and she's a leaking, wtf! It ripped when I reinstalled them, make matters worse no parts store on this island has um, currently a resident of kodiak ak and only 2 stores, anyway had a old tb lying around and stole the rings of it, they were flat but holding for now, to scared to restart her again tonight so I'll see what tomorrow brings...
