Rim Interchange???
apache
Central coast of Kali
Anyone know if the rim bolt pattern off a late model Silverado will fit early 8 lug pattern like a 85 Burb? what about "standard offsets" from one to the other?
The bolt pattern is the same. As for the hole in the middle, don't know. Should work. I have seen some older trucks running the newer rims and doubt they did any machining to make em work.
Backspacing should be close to what the old trucks had stock.
