rim refurb job for my plow truck make over
sweetk30
Back to play nice .
in the back of your brain
last night i took the tires off and checked all the rims on the balencer for any major bends. didnt find anything out of the normal for older stock 16x6.5 8lug stockers.
today i took them to my companys other shop and sentthem threw the rim blaster/striper/cleaner. the pic of the rim before blast was the best 1 that was used for the spare.
then the rims went threw the machine. it has steel shot in it about the size of a bic pen roller ball. there is 2 rollers inside that spin the rim as if it was on a axle rolling down the road. this lets them get hit from all directions. each rim was inside for 2 min - 3 min dependent on level of rust.
when thay came out thay were in the 110* temp range from the masive heat of striping them. if thay are left in to long thay can get to hot and actualy warp and become out of round.
then i took them over to my buddys paint shop and he is painting them bright white with epoxy based primer. as i like the epoxy primer best for my stuff. we do powder coating with a primer base. but i dont care for the end finish my self for my own personal tasts. thats just me tho.
as soon as thay are painted i will get finished pics and then mount up the tires and balence next. then i will get ready to bolt them on the truck.
and i have a set of the center caps from my crew cab build that were stockers. ( actualy were the rims/tires come from ) that will finish all of it off perfectly.
the rims off crew cab build with caps on them. will be all cleaned up and white with clean center caps.
few more pic.
rims with white tinted ppg epoxy primer in spray booth.
then 3 of 4 center caps dirty then cleaned with purple power cleaner . 4th center cap at body shop. had a dent in the hub hole area he said he can dolly it out real easy. this will make it look better.
well been a bit but got my 2" spacers the other day off ebay . decent quality for the buck. was like 115 to the door. set of 2 with studs/nuts installed.
cleaned and checked wheel face seat area on hub/drums. then used some locktite on the treads and clamped them down to 140ftlb as i would want them to stay on and the wheels are 120 ftlb . so if any thing should come loose it should be the wheels not the spacers.
and i didnt have to cut the drw long studs down at all. the spacers fit and left the studs just inside by around 1/2" before flush.
only thing i found was the spacer studs were not set in all the way. thay drew in a little bit more but bottomed out just fine. will recheck in a few days of little town driving.
the spacers let me install my factory caps on the rims. since this was a c&c drw axle i needed them to make it a srw axle the cheep way.
in the end i think it came out just right. old school work truck look.
79k30 4"hd lift front ord hd shackles. 4" ord flip rear 9 leaf 56" and 1" block. 2" body lift for 2wd cab on 4wd truck. 235/85/16 goodyear extra grips on the stock rims.
looks good!! now I guess you can sell me those Western Slotted Mags!!
those look bitchin, i did the same thing just 3/4 caps. i cant find any damn 1 ton caps. nobody wants to give em up!
stock caps look bitchin on anything fo sho!
yall got some rust problems dont you lol
oh i was gonna ask you where you got that done at, theres a wheels america somewhere in new york, i got mine done at my work at the san antonio store.
I glass beaded mine, but I just rattle canned them on my Suburban. I really like the way they look when they are clean, and with nice hub cabs.
Martin
