DEMON44
Low-Tech Redneck
If you use split washers and regular nuts, like everybody seems to. I stand by my opinion.
Sent from my Desire HD using Tapatalk
but the secret with rivets is that they put them hot, and then they shrink for extreme clamping force.
You can do that with bolts, but check first what heat will do to the bolts metalurgy first.
my opinion....
I think the whole "it'll vibrate loose" crowd is waaay overthinking/worrying about this...
how many parts do you bolt to a frame, or anywhere on a vehicle for that matter, that aren't subjected to the same thing? 92% of this forum will bolt a shackle flip to a frame, and I'm pretty certain ideal hardware isn't used 1/2 the time, and how many times do we here about them getting loose?
if the PROPER hardware is installed correctly, I see absolutely no issue whatsoever.. pinched locknuts being the key...
That is why I am stating this now.I agree with this statement,
When is the last time someone checked their Bolt on trailer hitch, or chevy engine plate bolts.
Those always had a bolt-washer-steel-steel-washer-pinch nut
and just a reminder to all, technically, the pinched locknuts are a one time use item... not meant to be taken off and on repeatedly....
