I've had the steel for over a year, so I'd have to go find my reciept to get the poundage rating, but the main frame is 10" channel and the deck frame is 5". The main frame has 3" channel x members on 48" centers front to back, including a couple crossmembers down on the axle hangers per Dexter's instructions. There are two 6" channel crossmembers in place of 3" in two critical stress points in the trailer. The pictures above should show placement pretty well. The torque tube running through the center of the main frame is 4" square that I believe is 1/4" thick. The deck will have 2" square tubing crossmembers on 16" centers. Every other xmember will be 1/4" square, while every other will be 1/8". So, as we lay in the x members we will start with a 1/4" piece, next 1/8", another 1/4", you get it. The idea is to save some weight there. Roughly 160 linear feet of 1/4" 2" square would get heavy quick.
I'll go dig my receipt up later and get the poundage, but something tells me I want to say 14lb on the 10".
