Maybe its NOT fuel related??
Could be its not a fuel problem,seeing you replaced nearly everything in the entire fuel system!...maybe a pick up coil in the distributor,or the coil is going south?...but its weird it only does it on hills or hard pulls..maybe the gas cap isn't venting and its stopping the flow of fuel??(wont let air in the tank)..I'd replace all the rubber hoses and steel gas lines,if they look even a bit suspicious..maybe "T" in a fuel pressure gauge you can watch while your driving,and see if pressure drops next time its acting up?..
My sister had a Vega that would run about 1 mile before "running out of gas"--I put in a new electric fuel pump,in the gas tank of course--it ran great for a few days..then did the same thing!
--I assumed the new pump might have been defective,it was rather noisy compared to the old one (whick ran and pumped great when I hooked it to a battery!
)--another new pump was installed(in her drivway in snow,in january!
It did the same exact thing the next day..at the same spot 1 mile away,it dies,and it always started back up before,and you could limp home,might have to pull over a few times,but it would make it--but this time it would not re-start,and I had to tow it to her house..
The fuel pump was working--I took off the gas line to the carb,turned on the key,and got a shower of unleaded!--so I ruled the pump out(it didn't work when I tested the others this way,so naturally I thought the pumps were junk)..I found a large hornet(wasp) stuck in the gas filter that goes in the carb behind that big nut..AH-HA!! I thought SURE that was the problem!--but after putting in a new gas filter--1 mile away,it stalled AGAIN!
..now I'm really getting pissed at this POS!.....
Towed it home,and let her borrow MY car!--while I tried to get her Vega to run more than a mile..I called a few garage mechanics I deal with at the parts store,and told them what it was doing..one guy said "Replace the oil pressure sending unit!"
--But WHY??--the oil light worked normal--came on with the key "on",shuts off after its running,just like it should!..
BUT--its also tied in with the fuel pump wires!--sort of a "kill" switch,so if you lose oil pressure,it shuts the fuel pump OFF!
..I kinda knew that,but never really thought of that until he told me !!..replaced the oil sending unit,and it ran 3 more years until she sold it with NO problems!--I ripped my hair out on that car--and spent a week under it in slush putting in fuel pumps,and about 100 bucks worth of other un-needed parts!
--is the oil pressure switch on later trucks set up the same way??..something to consider!..
)..It did the same exact thing the next day..at the same spot 1 mile away,it dies,and it always started back up before,and you could limp home,might have to pull over a few times,but it would make it--but this time it would not re-start,and I had to tow it to her house..
..now I'm really getting pissed at this POS!.....Towed it home,and let her borrow MY car!--while I tried to get her Vega to run more than a mile..I called a few garage mechanics I deal with at the parts store,and told them what it was doing..one guy said "Replace the oil pressure sending unit!"
--But WHY??--the oil light worked normal--came on with the key "on",shuts off after its running,just like it should!..BUT--its also tied in with the fuel pump wires!--sort of a "kill" switch,so if you lose oil pressure,it shuts the fuel pump OFF!
. Timing wasn't checked, but again, no other symptoms other than on the two grades. All the hoses were checked. Also checked for vacuum hose problems.
Why does this happen? Does the shop shortchange people on oil as a rule (it's happened before at different places), or do they not warm up the engine then check the oil level again before they release the vehicle to the customer?
)--many of the customers were shocked when we told them,and said "but I just had my oil changed 2 weeks ago at "Jiffy lube" or wherever!..
