Trailblaser1
Registered Member
For Sale near new PSC hydro assist steering gear cross over conversion, with ram, Pump, Fittings Hoses, Ram is 1.75'' X 8" stroke and gear box is a GM ported high pressure PSC steering gear box.
Part #'s
KIT - PSC Motorsports 80-87 GM 4X4 Cylinder Assist Kit w/ Cross Over Steering - PSC-SK320
SKU #: PSC-SK320
Individual parts as listed @ PSCMOTORSPORTS
Gear Box - PSC- SG041MR (2WD needed for cross over)
Cylinder - PSC- SG2201
Fits K5 Blazer also fits other 80 - 87 GM TRUCK/SUV frames, Comes with a drop pitman arm for a 4" leaf spring lift, a 3/4 ton chevy truck front axle (8 lug 10 bolt 8.5"), minus the brake calipers brakes and rotors, Good hubs, gears, shafts.
Pictures show how I installed the steering upgrade for my application and budget at the time. It is what is listed TRUE Hydraulic assited Crossover steering assist set up, bolt on kit unmodified. Just need to get the upper High Steer arm, tabs, rod ends. Those you will want new. Or run it like I have done. It works great either way.
I drove it a few times on 4 wheeling trips and now upgrading to full hydro set up and a 60, it has some scuffs and surface rust on outside of ram (shaft is good no scratches/scuffs) and box, but no leaks or damage like I say NEAR NEW CONDITION. Works great, I had 37 x13.50 x17 BFG Krawler TA's Sticky Compound, and never had any issues turning with hubs locked on the trail (open Diff no locker) But With a Locker or welded its a HUGE improvement on the Trail, Roads, gravel or black top. Best way to go when lifting your pick up or blazer and running oversized tires on a trail rig or daily driver.
Selling as a kit but will part out seperate for steering or axle.
Contact me with your questions I am happy to discuss more details about these parts.
Thank you.
Part #'s
SKU #: PSC-SK320
Thank you.
