Rod and main clearance?
y5mgisi
1 ton status
Portland Oregon
Im assembling the lowerend of my 500 today and need to get plastiguage still. Does anyone know what the actuall clearences are supposed to be? I mean its probly something like 0.003 or somthing like that eh?
Cliche, but the manual should say, if you've got one. I suspect one of our engine builders can either find that info out as well, or knows it off the top of their head. :)
y5mgisi said:
cliche? do you mean that checking them is cliche?
Pretty sure that Dorian meant that his cliche was "Check the manual." ;) I think even Chilton's has that stuff, no?
-- A
Ok, i'm assuming your speaking of a caddy 500? If so then the clearances are...
rods .0005-.0028"
mains .0013-.0026"
thrust clearance (end play) is .002-.012"
