I will add this.
While the vast majority of us use 1.75 .120 wall. With the typical weight of our vehicles, we should be using 2".
That being said most recreational wheeling rollovers are more mild than in a race situation and I thing design is much more important than tubing size
I agree with this.
In regards to the double B pillar, some off-road competitions are requiring double b pillar setups that are tied together...and some require an "x" behind the driver...and some require both. Obviously double b pillar is stronger, but unless your an ultra 4 rig, I deem it as unnecessary, just my opinion though.
I was wanting to use 1.75" tubing, but was forced to use 2" cause the buddy who let me use his bender had a 2" die, but to be honest, I'm glad I used 2"....looks good on a big full size. I also used .120 wall same as most everyone, however I used HREW instead of DOM mainly because of cost....DOM was over double the price of HREW when I purchased, and as blazinzuk said, I'm just a recreation wheeler and didn't think it was necessary to use DOM for my purpose...so decided to save the money and go with HREW. However, I feel just like blazinzuk that you can make up for all of that with a good designed cage that has good bracing in the common spots that will see stress in a rollover situation.
I'm not sure if mine is a great example of anything since I built it by myself in my little 2 car garage, but I tried my best to make function the most important while trying to make it look good and have the lines flow well with the vehicle. I think it turned out good and I'm pretty confident it will hold up to even a multiple roll-over situation...maybe not a desert fast rollover, but I don't think my big fat rig can go that fast anyways, ahaha
pics just for fun, though I think just about everyone has seen them and is probably sick of them:
And I just added this cross-tube on the b pillar so I could have a place to mount my tabs for my harness's, and it added some strength
