T
tenderfoot
Guest
What about instead of the U, two tubes running front to back same width as U?
Or even a little narrower
Yeah, the long straight bar probably isn't needed. My main reason for keeping it so far is to have a place to hang a couple of grab handles from.
This seems to work good (rear section). Her head was right in the center of the open area.
The front supports will need to stay in at B and out at A. I may even incorporate the same offset X pattern to make room over the front seat heads plus I like the supports hitting the outer A corners.
Didn't have time to watch the whole video, but will comment more later.that cage will fold like pretzel, especially the back half.
That was my first thought too but then the tube gets close to being overhead again.
