there are only two gauges that work in my truck. the tach, which is aftermarket and screwed to the column, and the speedometer, which is probably wrong. the others are either not hooked up or have enough paint overspray that I can't see them.
my seat is in the same spot it was before the cage. I think.
its not as easy to slide in and out as it was because of the door bar but its not that bad. a tilt column would make it really easy. I have one but am to lazy to swap it, and I don't have the key.
I will try to remember to get some better pics from the other side. I didn't take any because the sun was shining directly in the camera lense and I could not reposition the truck.
