Roller Rockers
blazerguy 90
EL Sobrante, CA
I was thinking of adding a set of roller rockers to my 90 K5, I know the stock ratio is 1.5, if I went with 1.6 would they work and how much of a gain would I see over the 1.5 rockers ?.
Welcome to CK5.
Yes they'll work. They'll also put more stress on valve guides and valve springs. The gain with a stock cam will be minimal.
yes, you can use them, but make sure you get the narrow bodied self aligning version, as the standard body rockers will not clear your centerbolt valve covers.
what labor? pull 16 nuts, and install them. nothing to it really. plus, reduced friction is your friend.
if your engine is stock. Roller rockers are a waste of time and money. You will see very little gains by installing them.
Maby make a little more torque, thats about it.
There are a lot better and cheaper ways to make power on a TBI engine than roller rockers.
A '90 motor can have either the self aligning rockers or the regular style. Check it out first in advance.
I don't think you will even feel a difference for the $200 spent.
[ QUOTE ]
[/ QUOTE ]
no it cant, all centerbolt heads use self aligning rockers.
Umm, since when?
AFAIK, Vortecs were the most commonly used heads with self aligning rockers, although there may have been limited usage before that, I seriously doubt trucks before '96 used self aligning stuff.
I know full well that centerbolt does not=self aligning rockers.
all post 86 engines used them. there is nothing special about the "special" rockers that you have to use with Vortec heads, they are the same production pieces that have been used since 1987. they even carry the same part number. i've read the GM parts catalog, no point in arguing this one any further...
have you owned your sub since 1989? its possible that someone thought they'd be cool and replace the rockers at some point with non guided rockers. they will bolt on, but that is not the way they come from the factory.
There are two head castings....One uses the guided rockers, the other one doesn't.
When I replaced the heads, it had the guided ones installed. After some research, I found the heads I was using required the non-guided rockers /forums/images/graemlins/waytogo.gif
[ QUOTE ]
[/ QUOTE ]
I've seen that too. A 1988 305 with pushrod guide slots in the heads and guided rockers. /forums/images/graemlins/dunno.gif GM produced quite a few engines that way around that timeframe.
