round 205 adapter w/ ford 205 case
I'm 99 percent sure they are different bolt circles. I'll be at the shop later and I'll measure them to be sure.
Jimbo
Well, I'll be damned, the bolt circle is the same; TH400 adapter bolts right up! Notch the adapter for the shift rail, and you're good to go. :cool1: No, I haven't had time to work on the burb, been working on the tow rig and acquiring big blocks with the gas price scare. :crazy:
Jimbo
the ford 31 spline case has the same size bearing as the 10 spline chevy cases i belive so im not sure how easy it would be to swap in a 32 spline input
NorthWestFab seems to think otherwise...
Ford Married - Large Bore - 31 spline
Ford Divorced - Small Bore
Dodge Married & Divorced 23 & 29 spline - Small Bore
GM Married - SM465 10 spline, TH350 - Small Bore
GM Married - TH400 32 spline - Large bore
http://www.northwestfab.com/rebuild.html
yup i have a 31 spline input and bearing sitting in my garage..
i'm pretty sure its the larger bearing setup.
