Have you checked the MAP sensor? and the vac line to it? The symtoms you are describing are pointing my brain towards that. You have one from the running truck you can swap over to check it right? It's worth a shot anyways...
02 and oil will self combust w/o an ignition source...it was a pretty big fire ball...all they need to do is meet each other, not build pressure
So I ordered an ALDL cable and had it overnighted. Should've done this awhile ago, but I'm cheap and thought I could do without it. That's what I get for thinking.![]()
They fixed a ground wire and the wires going to the coil kept coming loose. So today I brought them a new coil harness.
I sat in the parking lot tweeking the TB. I finally got it to run without the SES light coming on, but it still doesnt idle smooth. I might just go get another TB and see if any other problems arise before I move next week
The guy said he put it on the machine, but the aftermarket parts weren't being nice to the machine. Is this true, or did he just hose me out of money for nothing?
I think you should rethink your statement because oil is pretty much everywhere and O2 is also pretty much everywhere. An O2 tank is under pressure, that is why when you oil your gauges they can go boom when opened. I'm not touching your other statment but you have to have O2, fuel and ignition to have fire. Fire is just a chemical reaction, so is your boy scout trick, only it is causing ignition of the fuel and O2.
