RPM Offroad Dana 60 - 30 or 35 Spline Drive Flange Kits (COMPLETE KITS)
RPMOffroad
Bristol, TN
We have two kits available at this time: All the same except the caps
1) RPM Offroad Black Anodized w/ RPM Logo which includes:
*2-Double Heat Treated Drive Slugs (not just heat treated once like others)
*2-Aluminum Caps
*2-Drive Slug Eliminator Pucks
*2-Slug Spacers
*2-Hub Snap Rings
*2-Axle Shaft Snap Rings
*2-Cap Orings
*8-Stainless Socket Head Bolts
*8-Copper Lock Washers
2) RPM Offroad Black Anodized w/ HEAVY DUTY EDITION Logo which includes:
*2-Aluminum Caps
*2-Slug Spacers
*2-Hub Snap Rings
*2-Cap Orings
All Kits are available for Dana 60 - 30 or 35 Spline - they will run $199 Shipped with a LIFETIME WARRANTY!!!
We can also do the kits without the Drive Slug Eliminator Pucks if you don't think you will need them for $170 Shipped
You can just give us a call at the shop 423-573-3300 or just simply paypal with a description to [email protected] and we will get them right out! Thanks Jereme
Thanks for the flanges. They look great & fit & finish was excellant. Here are a couple poser shots.
I'm not entirely sure what these do, but they look sweet. Can I run them on a rig that see's regular street duty without issue?
They are more for the hardcore wheeling crowd. They replace your locking hubs with a splined piece of steel called a slug. Your front end is always locked in.
You can remove the 4 bolts & 2 snap rings & slide the slug out. He sells a piece of alum (slug eliminator) that goes in place of the splined slug. The alum piece is not splined so it alows the axle to "float" & not spin. So to anwser your question yes you could run them on the street, but you can't just hop out & lock them in. It takes a minute to remove the slug eliminator, & install the spline slug.
when you run the eliminator plugs, don't you still need to use the axleshaft clips?
I would just to keep from loosing it. But I can't see that it would really matter either way. My shafts will not slide in far enough to bind when you steer.
