Desert Rat
Fetch the comfy chair
Ok, here is my setup. 76 Blazer with GM crate 350 with no mods other than Doug Thorley headers an MSD HEI distributor, and Edelbrock intake with Edelbrock Q-jet. I've swapped in a 700r4 transmission and I have a doubler transfer case setup with NP203 rangebox up front and NP205 in the back. The drivelines are HAD's w/ a D60 up front and Corp14ff in the rear w/ 35" MTR's and 4.56's. Now, here is my problem. Last wheeling trip over the Sonora Pass, the rig was really dogging it. In fact, I had to put the TC in 2:1 a couple of times on the really steep hills just to keep up the RPM's to generate enough power. Granted, I had a full load of gear.
Now, during this trip I couldn't accurately see what my RPM's were vs. the speeds because my speedo was way off. I've since obtained a ratio adapter and it is much closer. It still reads a bit slower than actual speed, but is within 3-4 mph at least. So, I take it out on the highway today after installing the ratio adapter and find that I'm turning about 1600 - 1800 RPM's at 65 mph. According to the chart, I should be about 2800 RPM give or take. One chart says an auto speeds it up a tad but an overdrive slows it down a tad so that should even it out. However, 1000 RPM below the chart? What gives?
Anybody else out there have a similar setup? The TC's should be a 1:1 and not a factor in the equation I would think. The 700r4 I had built didn't use any odd ratios. Could all the weight with the heavy axles, full roll cage, winch bumper in front w/ winch and heavy bumper in back with full size spare put too much strain on a stock 350 engine? You would think it wouldn't change the RPM's but maybe? I don't want to spend more bucks to go to 4.88's or 5:13's if I don't have to.
'cuz he's in a *smog* state
... no big block for DR, without getting an exemption and getting the attention of the DMV.
