Something else I noticed and wondered about.
On a 2 piece drive shaft, where the angles change the same at the same time, (the same as a front axle) , you need to have the 2 pieces timed correctly or it will bind..... I noticed today that the ujoints in my front axle are far from timed correctly.
Which could be why when it's locked and I turn, the wheels do NOT point the same direction... One will wobble in and out.
I'm going to try and time the ujoints for now to see if that helps
