Have you disconnected the plug from the printed circuit board yet and inspected the circuit board termination where the plug makes contact? I had a vehicle once that gave me some fits and it turned out that as I had plugged the connector into the cluster one or more of the terminations from the circuit board got twisted up and where causing a short (it's been years ago and I can't remember exactly what was going on but it's definately something to check if you haven't already).
Yes...brand new circuit board from LMC....nice crisp and tight.
There is something that is puzzling me now....when I first found the correct wire on the schematic and attached that wire, the headlight switch stopped making the gauges move....
I am beginning to think that whatever is causing this gets "moved" or jarred....or something...in a weird way the headlight switch causing the gauges to move is sort of intermittent...however, I am not sure that the gauges are or ever have been acurate or working....I thought once that the temp gauge was...but I can't say for sure that the fuel gauge has ever worked correctly....
