Running radial tires on h-1 with mag. Insert
olbattlebuggy
Registered Member
Cleveland, Ohio
I've heard a rumor that you cant run radials with the H-1 magnesium inserts and that you should only run a bias ply tire.. is this true or am i gonna be ok running my BFG all terrains i have on these ? if not, what can i do to remedy this situation ?
you cannot use the magnesium beadlock with radials and the 8 bolt H1's.
with 12 bolt H1's you can run the radials with a rubber beadlock.
with 8 bolt H1's you can run the radials with a custom cut PVC beadlock.
or like me, i dont plan on airing down, i dont go anywhere its necessary, so i will run radials on the 8 bolt H1's with no beadlock, and run 30psi in them.
