Rust repair/Rock slider pics
MEK5
Maine
There seems to be alot of posts about rust repair and rock sliders here lately so add some pics.
I had plans to replace the rockers with tubing for the past couple of years because they were getting pretty bad but would think about it only when the inspection was about to run out and ended up just welding on a quick patch here and there and getting a new sticker.After some poking around with a screwdriver it wasnt pretty!
I have the drivers side done and have started the other,I used 2x4 rec tubing and added 2 floor supports that are 2x3.The bottom of the door has been shaved 1 1/2",it is flat now.
Once the other side is completed Im going to use a rust bullet type paint underneath and reherculine the floor.
nice work, I think i will be doing something similar shortly...
Nice work. Gave me some ideas for a support under the front seat sheetmetal.
I'll be saving those pics for future reference. How strong do you think the sliders are? I'm betting you can support the whole weight of the truck on those bad boys!
Nice job! I just did mine a couple of weeks ago pretty much the same way but I think yours look a little better than mine though. Can you take a picture of the bottom of your shaved door, I would like to see what it looks like.
Hey Thanks all.
My Blazer has been down since July with this project and I miss driving the rattlely old girl!
The sliders probably could be done in a couple of weekends but the body rot is what really bogged this project down and some burnout also.
I am not overly proud of the way the first door came out but its solid and no ones going to see it except me and 34,000 Blazer freaks!:haha:
I laid out 2 lines one at 1 1/2 and the other at 3/4 and cut there with a cutoff wheel,this seperated the inner from the outter skin.
I made 2 cuts under the door where it starts to curve up so you can hinge it up and take the taper out and then rolled the extra 3/4 of sheetmetal over and tack welded.There is a reinforcement bracket for the door hinges that you will have to cut part way thru bend back and reweld.
Heres a couple of pics that really dont help much.
man that looks really good. ive got some rust in that area as well. hmm
