Rusted together stuff.....
Blazin'Grrl
Indiana
My trailor hitch is one that you can take out by pulling a pin out....well, all of the assembly has rusted together...besides just cutting the whole thing off, is there anyway to free that stuff up? I doubt it, but thought I'd ask.....
<font color=purple>Sarah</font color=purple>
<font color=purple>
'83 K-5 Silverado Blazer
or after that WD40 find a shipping dock afterhours and slowly back into it (so long as the hitch sticks out farther anything else!) (I guess any building would do, but I was thinking of those large steel stops that the big rigs back up into)
<font color=red>Steve88</font color=red>
88K5 Silverado
[email protected]
Mix equal parts:
1. WD40 or other lube-goo spray "panther piss" etc.
2. Patience, and a torch if you have one
3. BFH (big ... hammer.)
I find particularly that the BFH, or the modern equivalent, the handheld grinder, solves many such problems ;-)
-- A
'74 K5 Blazer "Tank Grrl"
'77 Chalet sans Blazer
and more to come...
See if you can find some stuff called Blaster
I used it the first time on brakes, I had to replace the rear cylinders, and they were so rusty it would not budge. Sprayed on blaster ler it set a half hour(got a beer) and the stuff came right apart. It kinda eats rust.
<font color=green>Eagle86K5
<font color=red>Only guy I know that can get out of line in a one car funeral
why not pull the pin, wrap a tree saver around a big tree, hook a tow strap to your hitch, then hit the gas!
'77 K5
<font color=red>mudfanatic</font color=red>
Probably doesn't need to be said, but to err on the side of caution - be careful with a torch in that area. I removed a similarly rusted receiver hitch with an eight pound hammer. Good luck.
GM sells there own penitrating oil...i think its as good as PB Blaster or better....and yes you might have to use the ole Blue Wrench...with some elbow grease attached to a 4lb or better hammer!!!
AZBLAZER
1979 K5
1976 K5 Chalet
1972 K10 Suburban
uhh....the pin is rusted in too
<font color=purple>
Yes I also had this delema
and the fix was liquid wrench heavyly aplied then drove to a field backed up to the biggest tree hammered the pin out useing a bolt small enought to just fit through the hole.
bang bang bang until the pin comes out
now hook up the tow strap to the tree and hitch jump in and nail it!
Be very carfull when I did this the hitch came out and flew back oh about 200ft wow I didn't expect it to fly that far but it did so watch out.
good luck
Burt4x4
Rock ON!
Cool, I hope mine rusts in.
DangerBrett
<font color=blue>harder, faster, longer, stronger</font color=blue>
That's just plain mean......you guys aren't very nice or compassionate! I hope you metal starts to deteriorate and biodegrade from the sun.
<font color=red>MICHIGAN BLAZER
<font color=green>89 Fullsize Blazer
87 Cherokee
65 IH Scout
We used a air hammer on the ones at work to brake up the rust, sometimes it took a combanation of oil and hammering it
C'moe
<font color=black>the blazer is "Back in Black"
