tool build babble for the bored....
As alluded to elsewhere, I'm doing some of infamous 20 ton HF mods... figure I'll document them here..
while I bought the unit back in August for the fUrd to replace the old 12 ton unit my boss had ruined, and knew of lots of stuff to do to it already, I've been heavily searching vids on it to see what's possible... I also have a few things, and approaches to mods I'm going to do that i haven't seen others do..
apparently the base unit comes in 2 iterations, one where the top is welded, and one where it is bolted.. I've read people actually saying the bolted together version is actually better... the one I got was the welded, I'm ok with that...
the base, cheesy unit, minus the top slide and hydro...
I've already decided I probably would have been better just going to Fazio and buying some stuff and building one from scratch, but whatever.. this is where we are going...
so, a list of things that are going to happen...
air over hydro unit going in... it came with a hand trigger, but I'm considering doing a foot setup mounted to the base I'm doing.. foot pedals are surprisingly cheap.. plenty of units in the $20, 25 range... we'll see on that one...
the jack will get a custom knob or lever to replace the hokey, pin/handle release lever at the base... I think I'm gonna try and turn a knurled knob on the lathe for that.. but I've seen lever styles work good too.. heck, one guy used a fancy garden spicket handle...
I also ordered a cheap $20 hand crank boat trailer type hand winch to mount to the top with a couple pullies at the upper corners down to the lower, pin adjustable cradle instead of doing the whole "juggle that while raising/lowering" pins deal.. gonna use a nice 1/4" rope for that for smoothness, as opposed to the cable that came with the winch.. the pullies are coming from McBible...
you can see similar in this pic.. tho I'm thinking of centering the winch...
on my end structurally, the main thing is tightening and strengthening all the sloppy arse components... the piece that gets pressed down has a literal 3/8" slop on either side and flops around like a fish on the dock welded by a drunk 9 yr old Taiwan grrl.....
I've seen guys do bolts threaded thru to control the depths and slide on the main frame, etc...
fug all that...
I whacked the ends off and am rebuilding them in 1/4" stuff to a tighter, smooth transition/slide... I considered some sort of delrin slides, etc, but figure thats WAY overkill...
also the lower, pressed against, adjustable cradle is being rebuilt for tighter, smoother sliding..
I'm also doing lockable casters on the bottom... I will be cutting out the bottom cross brace and building a stouter, bolt-in piece.. mainly so the upper and lower press bars can be slid up the towers for install, than the lower cross brace gets bolted in... thats why they are built so sloppy, so you can angle them inbetween the uprights.
I may just add some pads to the angle corner bottoms for the casters... but if I had some 3" x 3" angle kicking around, I'd just replace those hokey current lower pieces... it is conceivable that I may build a lower storage tray, or box that holds pressing accessories and is a place to mount a foot pedal..... I'll see what kind of steel/time I have..
oh, the other more minor mods are going to be welding "stop" washers to the front of the adjusting bars so they stop against the cradle when you adjust as opposed to sticking them too far thru the holes.... and replacing the hokey 2-piece hand handle with a 1-piece tube for fine feel hand pumping... and a holder for it on the frame somewhere for it....
also, I'm going to "pin" the pressing plates they come with. I did a 1/2 arse DA cleanup to surface the crappy cast pieces {my kingdom for a Bridgeport)..... but I'm also going to drill/tap 4 holes on each so I can install pins on each to lock them into the lower cradle, as opposed to slipping off and breaking your toe..
one of a few winter projects i'll be working on...
fug all that...
I whacked the ends off and am rebuilding them in 1/4" stuff to a tighter, smooth transition/slide... I considered some sort of delrin slides, etc, but figure thats WAY overkill...also the lower, pressed against, adjustable cradle is being rebuilt for tighter, smoother sliding..
on top of the sweet new comforter I got from her...
