?'s on mounting PA speakers...
Lotsa_Faith
Mckinney, Texas
?\'s on mounting PA speakers...
I'm getting a free CB from a pawn shop with a PA output. The PA is the main reason I want a CB. I am mounting it in a CUCV, and I want to get two small black speakers to put on the grille guard. How would I go about doing this?
Re: ?\'s on mounting PA speakers...
I assume you already have the speakers picked out and know how you want them mounted. Wiring them up is really simple. You might be better off wiring them in series so you don't blow the audio chip in the radio. To wire in series hook the positive on one speaker to the negative on the other speaker then run the remaining positive and negative wires to where the radio is and connect the wires to a headphone size plug (radio shack has them). Plug the plug into the PA jack on the back of the radio and you're done.
