So my DD 95 S10 2.2L 5speed is missing now. Its sounds like its not getting enough fuel. It'll idle fine but when you give it gas it'll bog/hesitate and sound like its only firing on 3 cylinders. Started happening about half way into a 2 1/2 hour drive and thought i was running out of gas. I filled up and made no difference. Also no check engine lights either. It has 184K on the odometer and I was thinking it could be the cat, fuel pump, plug wires, or another ignition related something.
