5 55Willy 3/4 ton status Joined Jun 2, 2001 Posts 9,946 Reaction score 0 Location Keizer, Or May 18, 2007 #1 I need the style with the u joint at the case with either u bolts or straps not the later model flanged style.
4X4HIGH 1 ton status GMOTM Winner Joined Dec 14, 2001 Posts 22,423 Reaction score 663 Location Fremont, CA. May 18, 2007 #2 You will need to have a 10 spline front output in case you didn't know. As far as i know all the 30 and 32 spline stuff is the flat flange.
5 55Willy 3/4 ton status Joined Jun 2, 2001 Posts 9,946 Reaction score 0 Location Keizer, Or May 18, 2007 #3 Thanks, I keep forgetting that part.
kennyw @squarebody.chop.shop on IG Premium GMOTM Winner Joined Jun 9, 2002 Posts 18,862 Reaction score 12,511 Location Stevens Pass Highway, WA May 19, 2007 #4 Unless you want to upgrade to a 32 spline shaft from a ford case... then you can run a u-joint.
Jimbo* 1/2 ton status Joined Mar 8, 2005 Posts 1,449 Reaction score 9 Location roswell, new mexico May 19, 2007 #5 If you have a 10 spline shaft, I have the yoke. If you have or want to upgrade to 32 spline shaft and 1310 CV yoke, I have that too. Jimbo Last edited: May 19, 2007
5 55Willy 3/4 ton status Joined Jun 2, 2001 Posts 9,946 Reaction score 0 Location Keizer, Or May 19, 2007 #6 so is my 78 205 a 30 or 32 spline on the front? If it's 32 can I just run the ford yoke?
kennyw @squarebody.chop.shop on IG Premium GMOTM Winner Joined Jun 9, 2002 Posts 18,862 Reaction score 12,511 Location Stevens Pass Highway, WA May 19, 2007 #7 GM never provided the 32 spline FRONT output shaft. Only the 10 and 30 spline.
Jimbo* 1/2 ton status Joined Mar 8, 2005 Posts 1,449 Reaction score 9 Location roswell, new mexico May 19, 2007 #8 What he ^^^said. And your 78 model t-case should be 30 spline. If it has a flat flange front output, it is 30 spline. Jimbo
