aknight_sa
so you are running a 496!!
can you share some of its specs with us?
so as long as i am not going to use paddles then the 12-bolt should be fine? (trying to keep the budget low)
what about the engine?? any suggestions??
whats the specs of yours?
Are you really in Saudi Arabia? If so i doubt its going to be easy to find D60s. I didnt even know Middle eastern countries had american vehicles over there, unless they have a .50 cal![]()
I have seen guys run 10 bolts with paddles but I personaly would not do it.
Engine there is no many options. If you want quick cheap power NOS is the way to go.
As for mine, my truck is a bowtie block bored out to like 364 14.5:1 compression, victor jr. intake, brodix heads, and lots of other goodies.
For drivetrain I got 10 bolts front and rear with 3:73 and a turbo 400 mated to a NP208. Had this set up for almost 7 years and havent broken it yet.
the specs on the motor before i started my rebuild were-holley 950 carb modified by pro fuel sytems, the manifold is a Dart single plain hi rise oval port , the heads were stock oval ports from an early 396 bbc, the cam and lifters were isky hydralic roller-the cam specs were 228/232 at .050 duration and .550 vavle lift. the bottom end is eagle 4.250 stroke with h beam rods and 9:1 compression flat top pistons. still able to drive around on pump gas but love NOS
i thouhgt of installing NOS a lot.. but am afraid i wont be able to find a place to refill the tank here... unless i can do it somehow at home
how much is the boost in power if i installed NOS???
how much is usually sprayed??
and how much would a 10lb tank last??
