What do you guys use to sand down your tack welds on body panel patches? I've been using a 36 then 80 grit on a right angle die grinder. This works obviously, but the welded area becomes wavy. Should I use a file at the very end to get it flat? If so what type and TPI? I also keep hearing about curved or rounded files? What are those exactly?
Thanks!
Thanks!
