GNEEnterprises
Registered Member
I have a 97 K2500 (8 lug) that I plan to put a SAS kit on. I already have several donor 73-87 chevy trucks sitting in my yard, to include a front D60, NP208s, springs, etc. Even though I already have the D60 (with matching gear ratio), it looks like the T-case swap will be a big hassle due to the speed sensor needed by the 4L80e. It looks like I would need a 91 burb NP241 with VSS, which are hard to find.
I plan on running 37" tires and a front locker. I plan to 4-wheel it harder than the stock IFS would allow. I also plan to tow with it.
Would it be worth the effort to use the chevy pass drop D60 even though I would need to swap in a t-case or would it be easier to try to find a driver drop ford axle to swap in?
