sb400 OIL PAN
Chris1972
Are there any diferences between a SB400 oilpan and from a 350 engine????? How can i tell them apart????
Also what is a good price for a used Dana60 front axle???
Chris
www.broadpark.no/~csteinsv/
Chris, might want to post this on the main 4x4 board as it is not really an ORD question. I believe the oil pan is the same for both the 400 and 350, but am not sure. Post over there and someone will know for sure.
As far as a Dana 60 goes, if you get a rebuilder (decent shape) for $750 you are lucky.................most cores even are going for $500 needing full rebuilds. Getting a D60 in good shape will cost you minimum $1000 up to around $2000............all US funds of course. Good luck............put a D60 in my K5 last weekend.
<font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
I have a sb400 too, but that's beside the point. I'm 95% sure there is no difference however let me tell you one thing I learned from working on a 305. Apparently there are 2 different types of oil pans that will bolt up. The difference is the space between the timing chain cover and the pan. One leaves a larger gap than the other. The good news is that they make a thicker gasket for it so problem solved. Recommendation: buy both types of gasket kits and return the one you don't use.
Stuck is a state of mind!
Mudstud
Most gasket kits come with both the thicker and the thinner front gasket for exactly what you're talking about.
All SB Chevy oil pans are identical except that the 80-85s use a passenger side dipstick, and the 86 and later ones use 1 piece oil pan gaskets and rear main seals.
If I were removing an oil pan, I'd definitely put out the $30 for the Fel-Pro 1 piece oil pan gasket for older engines. It's worth every penny and it eliminates oil leaks.
Tim
'84 Chevy K10, lifted, loud, fast, and 3/4 ton axles
The other replies sum it up
Making the world better, one truck at a time.
[image]http://coloradok5.com/logo_ordsmall.gif[/image]
SW-ORD
