Anybody have serpentine style water pump pulley(s) they can measure?
My water pump pulley doesn't line up with my crank pulley by 1/4"+ and it's causing the belt to try and crawl out of it's "groove". All other pulleys and accessories appear to line up correctly but the water pump pulley is noticably out of alignment, inboard towards the face of the motor.
My pulley measures ~2 5/8" from the fan clutch surface to the outside edge of the furthest lip. It appears I need a pulley measuring 2 1/2" or just a hair less.
Fwiw, I'm running a Kwik Perf SBC serpentine belt conversion on a BBC. Per the instructions, I'm using a specific 454 crank pulley (purchased new at GM) and the rest is off of a salvage yard early 90's truck SBC.
