school me on steering columns
Kota4bye
Okinawa
My tilt column is all over the place, but so is theupper end of my steering shaft (xj shaft) Will the normal tilt coumn fix tighten all this up?
I just fixed all this on my rig.
First inside the steering column there are (4) 1/4" screws that have vibrated loose.
You will need to tear down the entire column to get to these screws. Yer gonna need a couple special tools.
2nd, on the end of the steering column where it connects to the XJ shaft there is a bearing and coupler that probably slid down with all the vibrations.
I took a piece of 1.5" tube & a hammer and gently persuaded it back into position.
I did a thread on the steering column. I'll try to find it & link it.
I can help you fix yours if need be but I know you have the skills to do it yourself.
Some folks would say just go to the junkyard and buy a new one but they just vibrate loose too.
Thnks, I read your thread, on it...just researching one more thing to add to the list.
These old Saginaw tilt columns are a PITA. When I got my 89’ Burb last October it was so bad that it would hardly start (rack and rod were damaged) and the turn signals wouldn’t work. After ripping it down I found the bolts had been loose for so long that ball bearings were missing and the upper bowl had to be replaced along with the bowl itself. What a hassle. Fortunately, I had a couple spare steering columns lying around to pirate parts from.
Pblaze725 did a great write up on the early tilt columns but the later ones with the headlight dimmer in the column are a bit more complicated as there several more little intricate pieces to deal with towards the top.
Here is a diagram of the same basic column used in the later columns with the column mounted dimmer switch. This is a 1995 G-van so it has a brake interlock switch that our trucks don’t but outside of that this diagram is the same.
