This is what I know: that np 208 is an aluminum case, chain drive and np 203 are heavy as hell, cast iron, also chain driven, and I know np205s are better because they are gear drivin. What I want to know: why do people mate np 203 to np 205 instead of a np208? Can you mate a np205 to a np208 what would be advantages and disadvantages?
Because the 208 isn't as stout and it's far from easy to do.
I made my own a while back using a 241, it was a TON of work. I like the gearing (though double low is more than enough, I hardly use it), though it will never be as strong as a 203 gear box.
Thread here.
Quick breakdown:
203/205: 2:1 and 4:1 options, easy to do with off the shelf parts, bulletproof, plug and play
208(241)/205: 2:1, ~2.7:1, ~5.4:1, much more difficult (required cutting the case half, welding aluminum, etc), lighter, definitely not as strong, parts are practically impossible to find (I made my own adapter because the 241 plate
wasn't available by anyone and I had to make a dozen calls to even buy the shaft, the only guy that makes this stuff is terrible with customer service).
So there is a niche for the 208/241 doubler stuff, we've talked about building the kits because there is some demand for them and they have some advantages. They aren't ever going to be as stout or easy as a 203/205 but they do have deeper/more gearing options and the kit would probably cost less than our current doubler.
In all likelyhood the final product would use the 241, just about everything about it is stronger than the 208, including the gearset.
