Sealed beam to ?? conversion
dyeager535
1 ton status
Solutions
Roy, Washington
Since my truck doesn't get driven much (few times a year), I can't justify the really nice LED lights.
Seems the H4 conversions are likely to be a much more cost effective option, for my uses. I need better headlights, no way around it, but I don't particularly need them to be real durable. Need to see further, need better illumination out to the sides, etc. I value others results that have done this. My daily drivers are much newer, and I have zero issue with their headlights. If I can get somewhere between old style sealed beam output, and modern car headlight output, I'd be happy.
Anyone here used this setup? https://www.amazon.com/Parts-Go-Rectangular-Conversion-Headlights/dp/B07NGRJ7F7/ref=sr_1_5?crid=1GGCNLJB13MSV&keywords=4x6+headlight+conversion&qid=1652344604&sprefix=4x6+headlight+conversion,aps,237&sr=8-5
I see some reviewers state they were a loose fit in the buckets, or that the light quality wasn't good (probably bulb related), but if I have to go out and source better bulbs, that's not a big deal if I'm only shelling out $70 for four of them. And as advertised, you end up with quad hi/low beams to boot, which I'd planned to do. (For $46 you can buy just the four housings, and get your own H4's FWIW link for future reference: Bare H4 housings)
If I go this route unfortunately I'll be pressed for time to install, but I'd love to do a comparison of before/after, to include before/after the relay modification to the headlight circuit.
My truck was improved enough with the relay kit and nice stock bulbs, Sylvania in a purple box I think, xtravision.
However, my experience with cheaper replacement headlight housings on newer vehicles is that China nails the look, but not the optics. (Edit: light scatters everywhere, poorly defined cutoff, etc versus factory lights, even with same bulbs.) I’ve replaced yellowing factory housings on a Ram and Acura with similar results. Both “CAPA” certified brands from rockauto. I had great luck with the 2nd Gen ram housings, but 3rd Gen are not as great. Just .02 on cheaper housings.
Dad’s burb is 2 headlight system and we have a hella h4 kit waiting to get installed. I’ll make sure to do before/afters.
I run the harness and headlight lenses from LMC truck with some great led bulbs i found, also Tahoe/yukon style fog lights to light right in front.
Really happy with this setup, i can finally see at night!20220509_174247.jpg20220422_174302.jpg
If you plan on the H4’s and not go LED you really need to add the relays to the harness to get the best out of them.
H4’s on stock wiring is ok. But getting the relays in the system will put the voltage to the h4 bulbs that they need.
I found my ‘75 had a voltage drop of over 2 volts at the headlights with the stock wiring. Engine running and the alternator putting out 14.5-7 the plug at the headlight showed right at 12v.
That difference in voltage is common to all squares with stock wiring. Put a different way, my ‘75 on relays and H4’s with the low beams on were obviously brighter than my buddy’s ‘78 with stock wiring and the high beams on.
I've done the H4 swap on both my motorcycles when I had them.
It was before the flood of chinese crap. Loved them.
  • Like
Reactions: TLW
I haven't ever bought new housings for the 4"×6" lights, but I have swapped 3 trucks with 7" round and 1 truck with 5"×7" headlights to Hella housings and had great results. I don't know if they have versions for the 4x6, but I would buy them if they did. Very nice beam pattern and fit in the trucks.
The problem with even the Hella's is that they are more than I really want to pay for such limited use. Gets me into the "mightaswell" territory for full blown LEDs. Which I'd do in a heartbeat, except the $1000 price tag.
I have not tested the voltage at the headlights now, but if the voltage drop is that bad (my alternator also puts out 14+) then perhaps I better see what the drop is now. I'd prefer not to have to change headlights at all if I don't have to.
I was unaware that beam pattern/cutoff was a potential issue with the H4 design. I suppose pretty naive to think that it takes no skill or effort to make an acceptable housing. And there is no point in swapping if I'm not going to end up with a guaranteed better result than I started with.
Ugh, those LFRB120 Holleys look better and better at ~$360 for two. If they are as good as it seems they are, no real reason to need to swap all four over.
I had not seen those Holley lights, those may be the best of both worlds. Stock look and better light.
I picked up a set of 5"x7" Hella h4's from Amazon, and unfortunately they were the euro version. They had a beam pattern that shot a beam off to the left to highlight the shoulder of the road in Europe, but in America all that would do is blind on coming traffic.
This is the photo straight from Amazon. The old reversed photo trick. (Look at the triangle pattern in the glass). Hella does make a dot version, although harder to find.
I sent em back.View attachment 412100
I had a set of those. They worked great!
I researched the E code before buying and everything I found said that there was no left side kick-up to the beam pattern as the DOT ones have because Europe requires that all major roads have the signs illuminated.
I can tell you that I mine were definitely E code with no left side kick-up.
I hate having choices lol.
I've always wanted a four hi/four low headlight setup, and while the Hella housings could be used for that, I'm not sure the Holley Retrobrights aren't so good that two of those would perform as good or better than two or four Hella conversions.
I'd like to see a comparison between those two actually, the old sealed beams are night and day difference, but if the Hellas are close to what the Holleys can do, it muddies the waters.
After having watched a video where the retrobrights were compared to the Philips offering, I'm leaning heavily towards the Philips.
I'm not a big fan of the non-stock look on them, but my truck is nothing fancy. I need to be able to see. At $120/each, I can justify two of them. I can't imagine four would even be necessary if they work as good as the videos show.
https://www.summitracing.com/parts/phl-h4656led
A little hesitant to put something on it that isn't heated though. Snow is a concern and I know unheated LED's are subject to getting covered in snow.
I installed a set of LED lights like this and they work well except I had the readjust the main lights down to keep people from flashing me after the install. Several different varieties but I went with DOT approved.
https://www.amazon.com/Headlights-R...lja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
A lot of tests seem to indicate that unless you are buying high end, name brand LEDs, at best they match halogens. At worst the old bulbs are better. Not saying those particularly are bad, there are tons of similar options, but with no cutoff those seem the type that don't actually focus the light where you need it.
What does the beam pattern look like from the driver's seat?
Trust me, for this truck I'd be very satisfied with the lowest cost option that satisfied. But on modern cars (IMO/IME) high beams are utterly worthless, because the low beams do much a good job. I'm looking for that sort of performance. I'm really trying to not get into a situation where I pay half the price to find out I'm not satisfied.
With the Philips being nearly half the cost of the Retrobrights, and arguably being better, it's possible lower cost options can perform well. But I've had a lot of dealings with cheap LEDs in other sizes, and generally I'm unimpressed with their performance. Looking directly at them they hurt your retinas, so you expect they will perform well But from the driver's seat, the light is useless and gives nothing close to a usable beam pattern.
Hey Dorian,
I had the standard Sylvania Silver sealed headlamps before and the conversion to LED was pretty substantial. Funny thing was every Sylvania I removed had the lense fall off in my hand. So much for Sealed.
I do agree the Halogen in proper lenses would properly focus the light and place it where you want. I dont think you could go wrong with the Halogen conversion. It was something I was seriously considering before going LED. With the LED only a few lights actually come on, on low beam. On high beam all diodes are illuminated and its like daylight but thats not normal driving condition.
I would have liked to seen a side by side halogen/led before my mod but couldnt find any real comparisons. I think the Halogen would work best for what you are looking for.
If you dont like them im sure someone on CK5 would buy them from you.
I believe that it really is dependent upon beam control. My wife's old 2011 GMC Acadia had HID in it. It was great on low and high beam, BUT not nice to oncoming traffic when the road bumped the nose up. Her '20 Buick with all LED'S is just as good, probably better. And dang near wicked on high beam. The reflection off of road signs is too much at times.
I have a pair of Rigid D2s with all four Bosch halogens on my '90 Jimmy and it doesn't have the range of her Buick, I don't believe.
The cheap lights send light all over and don't do what you need.
Leaning heavily towards trying the Philips 4656LED. Assuming something doesn't change by the time I can order and install them, which is still months out.
Price at Rockauto is $100/light:
https://www.rockauto.com/en/moreinfo.php?pk=11677181&cc=1050613&pt=11701&jsn=490&_nck=ZExt1ysfqhqWnq+EvUNdSyqlmez6jy1gNJMlusoX3OR6oZHmd95p79CSOLvI+bdPfX3T0uIFMzS5irYorKCVsG+YKVCIpi4yERr4ATczeuIO32StJx5mAKwwOJyS2RnrZTXTOrtEDlfW+wav9OMBljhEv4l38Z86G84TMtQY0+4g/cklPfptgEpUbSFoiOVJDd4ImzgXbJQFfM+LJdC3AXtJ3rfumyGB+GVLUAWiLO+oXkq2u6jsC6iyzo6VHeW8pZwPWo21xQw9lO4Cv3Q6ZyE23BVE+mBsJn6077TPaUUVXjs072tK1JRRW6wekmj7BrTBDpdDdawSH/kl+93YhARt6Wq90Vlm
Spec sheets are available here:
Interesting, one spec sheet says "low beam", but the 4656 is the high/low, and this one has the three pins. However in some videos it seems like maybe there is no high beam. Not a deal killer for me, but I've asked Philips and am awaiting a response on that. It should be more clear.
This video is what made me exceptionally wary of the low-cost LED's. But they also test the Philips which they approve of:
I suspect they don't "recommend" them at the end simply because Headlight Revolution doesn't sell those.
This guy has an initial and this 6 month followup video showing the Philips (also vs. the Holly Retrobrights), and I have to agree, especially for the cost, that the Philips are a better product:
Don't see that the Philips are heated, but I've seen tricks (cooking spray primarily) to keep snow from sticking to them. Not a huge fan of having to remember to do that who knows how often, but my use is unlikely to have me worry about that too often. I'm not often driving in snow in the dark.
Hopefully I'll have time when I get them to do it right...verify voltage to the stock bulbs, test illumination at distance, then install LED's and repeat.
