Glad YOU were able to easily fix it!
Awesome pic!
.....Excellent outcome.
In this case though, its possible that the positive terminal of the battery touched the body, and the small ground wire took the full load of the short.
Unless you have a spill proof battery, you need to pull it back out, and wash everything in sight with baking soda followed by good paint or heavy grease.
Good job fixing it yourself. Do yourself a favor and buy (or make) one of those top mount hold downs. Once is a learning experience. Twice earns you a Red Foreman "Dumbass".
Reading this, I can see now in my head exactly what happened and this is it.
And I just now understand what the small wire is- the jeep doesn't have one, and none of my other "old" cars had a sloppy battery so that small wire is something I never noticed until the k5.
So that answers one question.
The next one- I had no brakes when the truck died. That, I didn't understand at all. Unless I was pushing the clutch in my panic... But I don't think so. Pedal to the floor. I had to slam on the e-brake to keep from hitting the nice bmw guys car...
As I put in another thread, we ran a cable to the frame on my buddy's f150 then from the frame to the block. There is also a small wire from the cable end to his fender. We wanted everything grounded.
How true. #1 rule is you can never have too many grounds. I guess there can be a point where the redundancy becomes a bit ridiculous but ground problems can cause some of the most weird azz stuff you'll ever see.
