thewestwon
Registered Member
I recently extended my 25 gallon tbi sending unit on my '87 to fit my new 31 gallon tank. The pump is operating properly and the gauge was reading correctly when i first got it hooked up. Today, though, while driving down the interstate, the gas gauge went about 3 inches above full (the same thing it does when the sending unit is not hooked up) and stayed there. Since the pump still works fine, I'm going to assume the problem is not with the wiring on the sending unit. I've played around with the ground wire outside the tank with no luck. Does anybody have any ideas on potential fixes? I might also be noted that the only gauge that is not working is the fuel; everything else works fine.
