serious noob question
JOEDEZZY
TUCSON, AZ
Ok I've pretty much decided that my transfer case is a 203, judging by what I've read, I am assuming that it has been converted to part time 4 wheel, because the front drive shaft does not turn when it is in high, my question is what is the difference between high, high lock, low and low lock and how do I properly put it in 4 wheel drive (locking hubs,etc..)? Also if it has been converted do I only 4 low now?
Thanks that was definitly helpful, so how do I go about locking in 4 wheel drive? From what I was told, I put the the truck in nuetral, engage the transfer case, lock the hubs, and then back up 15-20 ft to lock everything in, and then to take evrything out, I would put the truck in nuetral, put the transfer case in 2 high, unlock the hubs, and back up 15-20 ft.
