Apocalypse
Registered Member
On my project blazer im having a problem with the transmission and stalling. first off right now im running 456/205 3.91 ratio with 35s im having to keep the engine rpm around 3000 rpm to get the truck moving (in the granny unsyncro low) or else it stalls. the truck shakes while letting out on the clutch and the engine tries to die. once in gear shifting to first is a pain and i usualy have to wind out to 4500-5k rpm to get enough speed before first(not granny) stalls out again. Is there some sort of special way to tune an engine for a manual trans vs auto? from what i read i should have enough gear not to have to dog the truck so hard to get it going in the 6.55to1 ratio.
idle, off idle, is it missing? basically is it fine no load?
everytime i let off the gas it was hell getting going in the next gear.oopsy..the cool thing about a manual trans is,,,, it does not matter how shatty the engine runs.
if there is no neutral safety switch, you can go down the road using the starter.i have done it.thats how i found out i had a locked up caliper on JR. i push it out of the doorway. {why waste gas starting it}. it was a bastard to move,so i check and guess what?drivers side caliper was froze.
