Serp belt conversion?
brans87
- In Memoriam -
North Carolina
Trying to think of any special or odd tools to carry before head out there this week in search for the conversion. I know one place that should have a couple but want to be sure to bring all tools might need. Anything off hand I should carry besides normal?
p/s pump pulley puller tool . to remove to get the 3 bolts for pump off to then get to hidden bolt on bracket to side of block . DONT need pump your old will bolt up . just the serp pulley .
can lube ( wd-40 liquid wrench pb blaster )
inverted torqs sockets ( star bits but socket version ) for the studs in the face of the block / heads that hold them brackets on .
get the pig tail socket for the newer alt you will need . not the same as our older alts v-belt style.
ok got p/s pulley tool not used in years since yet Honda/Toyota yrs ago. Got some stuff call inforce from BG works GREAT for rust etc! will grab my inverted torque sockets (know size?) Will make sure to grab the pig tail,along with belt if possible and year model just in case.
Hoping to find some other good stuff there also!
