big_truxx said:i am in no way trying to be an @$$ here... but people on here would do that?one has to know the propper tension of belts, but thats so simple and kinda basic.
I know the proper tension required on a V-belt, but when you have an alternator that consistantly looses tension you got to crank it up to keep the belt from slipping. I had that exact issue on an 78 malibu I used to have. If I set it at the correct tension and drove 15 miles the "gen" light would come on due to the slippage. It even chucked the belt once on the highway. I had to carry a 1/2" wrench and prybar just to make the adjustment on the side of the road periodically. Seems that the issue was really the threads on the alternator case where the bolt went for the upper bracket/tension adjustment were stripped down deep enough to let the bolt get tight and 1/4 turn more and it would loosen up. Drilling the hole out and tapping it for the next larger bolt helped for a while but it still did it eventually. Only solution for the longest time between adjustments was to crank the snot out of the belt and get it as tight as possible. Yes a new alternator should have fixed it but at the time I was low on funds and had to make it last.
Watching my buddies throw thier v-belts on thier street trucks (v-8 s10 and big block 72 GMC) while cruising Woodward in Detroit is another reason I would rather have a serpentine. The S10 would throw his belt consistanly during a burnout even with correct belt alignment and tension. The big block GMC just pitched his when he snapped the throttle to rev it up. For the effort it would take to install deep groove pulleys to try to combat the belt throwing, it would be just as easy to convert to serpentine and forget it.
I'm just wondering (besides Harryh3) how many of you v-belt fans have even tried running a serpentine setup? I know I've had both and you know what I prefer.
--I've seen serpentine belts last over 100,000 miles on my dads 76 Ford Torino station wagon "company car" he drove for the local gas company!--it also went 90,000 miles before its first tune up,and the plugs still looked factory fresh!..
what were they thinking on that one?
my bad
