Ok on my 87 k5 the ses light has been comeing on. So i went to check it with the paper clip method and it flashed really fast and went out and won't come on now
any ideas ?
any ideas ?
any ideas ?
.yup. k5 seem to run fine. When I get home I am going to try to plug in my scanner and see what happens.
. Well it works with the scanner so I don't know what I did
. Still getten the o2 lean code and the est changed code along with no vss reading which is hooked up so not sure whats going on.
which is good and bad
. As far as the speedo most days it works fine and others it works it just bounces until over 25 mphs.
nope haven't checked them all yet. Any idea which one is related to the vss ? I will have to check plus i will have to check the wiring cause the po had cut and patched alot of the wiring under the dash between what i would guess was a remote start or alarm and a really crappy radio install
