Set of Dana 44 or GM 10 Bolt 6 lug Spindles and Hubs
StevoandaRedK5
Dallas, TX
Either a full set of 6 lugs, or a single dana 44 hub with the smaller diameter inner wheel bearing, i don't need rotors. I will pay shipping, could probably fit them in a couple of flat rate boxes.
I have a complete 10bolt 6 lug if your interested in parts. Even has almost brand new warn premiums
Hey brian, let me know if you can post pics of that smaller diameter bearing hub. if not, if you say it's smaller diameter i'll take your word for it. also, how should i get you the funds?:deal:
Sorry, I'm slow this weekend.
The two on the right are the small bearing and the one on the left is the larger one for comparison. They're a little greasy, but that keeps the rust off of them. I'll clean it up before shipping if you want it.
One of them has a thread partially stripped a little halfway down, so I'll give you the other one.
Paypal or a check is fine. I'll PM you the details.
Sorry, I keep forgetting to post the dimensions.
For the large bearing spindles, the inner bearing diameter is 2.0" and the outer diameter is 1.625
For the small bearing spindles, the inner bearing diameter is 1.75", and the outer bearing diameter is 1.625"
Those are the only differences I can see.
I have a full 10b 1/2ton axle in a parts truck I'd be willing to yank them off tomorrow if your still interested. Let me know ASAP its getting scrapped monday.
908-692-0145
