Mav2u
Okay, found my 14 bolt SF out of a 90 4x4 with the 3:73 an gov lock. Gov lock not the first choice, but for $200 bucks I can't be choosy!!
So, how do I set up the new spring perches an shock mounts?
I figured I will be buying the spring perches from DIY4x.com for the 14 bolt.
They sell shock mount tabs, so I guess I should get those instead of trying to re-use the factory ones I cut off!
I've plasma cut off all the junk on the axle, ground the axle tube smooth for the welder to do his work. Since I can't weld at all!!
So, how do I setup the right angle an location of the spring perches? Is there a proper way to calculate it the location? Is there a certain angle I need to maintain? I've never done this before so any help would be appreciated!!! :-)
