I got the axle back from the welders! $55.00 bucks to weld on the spring perches an shock tabs. Also includes the setup time to measure the perches into position an the shock tabs since I didn't mock them up before hand. I just measured pinion angle an perch angle on the 10 bolt an then transferred the measurement over to the 14 bolt. We measured out the center an put everything where it belonged based off the measurements from the 10 bolt.
Knowing that I had to have 42.5" on center for the perches an about two finger widths for the shock tabs to the spring perches. Everything was on the mark when I bolted the 14 bolt up under the truck for the first time yesterday.
Now to clean up some of the old brake parts, then paint some pieces, an then put the drum brakes an the complete drum brake rebuild kits into the axle! Get the ujoint adapter from Napa tomorrow! Hookup the ebrake cables from the 10 bolt over to the 14 bolt. An then fill her up with diff oil and I will be done hopefully!
Things left to do
1. Get adapter ujoint from NAPA
2. Install new brake rebuild parts, brake cylinders, and brake shoes.
3. Get drums turned at mechanics
4. Install ebrake cables before brake rebuild with cables from 10 bolt axle.
5. Get new lug nuts. 14 bolt has larger lug nuts than 10 bolt. ( so get the lug nuts off donor axle to save yourself a couple of bucks! )
At the welders getting spring perches an shock tabs welded on!
Left axle view after getting it mounted under truck.
View from back after getting axle mounted under truck
