OK THIS IS WHAT HAPPENED.
Distributor Timing is very screwed up. When I started the truck she had problems starting up, i turned the distributor counterclockwise about 30degrees. Then I started her up again, and she started and idled at 2000rpms. So I ran outside and turn the distributor clockwise about 15degrees and it idled abotu 1100rpm. But I pressed on the gas, and it started bogging out. Finally I shut the truck off and I tried turning the distributor clockwise a lil bit more and I broke one of the frigen bolts that the distributor cap bolts to the distributor with.
So most likely im going to buy a new distributor and drop it in and guess with the timing.
However, the method of using the HAYNES manual with the rocker arm nuts. I used the method of spinning the pushrods until there was a little drag and then turning it another 3/4 turn. It worked because I cannot hear any clicking noise and when the truck was idle at 1100rpm it sounded good for the second before I pressed on the gas.
Any comments, solutions, guesses, I would love to hear them!
Thanks again for everyone's help because atleast I got her running for a lil while. And she does start up!
