Shackle flip
cojnit
Hawthone, CA
I was interested in using the shackle flip for my 1976 3/4 ton and was wondering what you folks suggest for use on the front for a lift to match?
Four inch springs of some sort, we carry Tuff Country, anything else will also work. Spring selection is a whole other topic. Basically you use the flip as a replacement for a 4" block or full arch spring in a 4" lift. So maybe that's the easiest way for you to look at it.
thanks, that Is kinda what I thought, but wanted to make sure before I made the plunge.
