I have a truck I need to fix that has been swapped to a 4bt.
It's an 87 k30 with ac and originally a th400 truck. The 4bt is not long enough to install a vac pump from a 6bt so I'm looking at electric options to run a vac system. Most likely a pump from a Ford 6.0l diesel.
How the hell does the th400 shift? if it has a constant vacuum will it shift ok? I have always thought the modulator does the shift control but they were gas trucks where vacuum varies.
Then the ac system I assume works off of constant vacuum but it would be nice to have the trans shift before the ac.
Am I at least on the right track applying full vacuum all the time?
