Mines still hitting my axel. What's required to run dual shocks (for some reason my blazer sees a lot of air time) Also, why aren't the shock mounts on the top of the axle?
IIRC you need another triangle shaped bracket for the other side of the 2nd shock (I have a set), shock spacers (I have a set) and I believe just a longer bolt and washer for the axle side. Don't recall for certain on the axle set up. They put the shocks on the sides of the axle tubes to try and combat axle wrap.
